Ilmainen PDF: "Solar Secrets" (Peter Lindemann)
ViestiKirjoittaja esaruoho » 13.05.2014 15:45
Kai tästäkin jotakin irtoaisi jos joku jaksaisi lukea?
Peter Lindemannhan on kuitenkin ollut tuolla Bedini/Murakami/Bearden/etc -skenessä jonkin verran aikaa -- ja luulisi että aihe on sen verran yksinkertainen ettei siinä mitään vapaaehtoisia valheita ja sumutusta kerrota hänenkään puolelta..?
http://freesolarsecrets.com/solarsecrets.pdf
esaruoho
Re: Ilmainen PDF: "Solar Secrets" (Peter Lindemann)
ViestiKirjoittaja jussik5 » 13.05.2014 23:28
No miksei jaksa ;)
Lainattua ja ihan asiaa Peter.iltä
"The REAL Reasons Solar Power Systems Fail
Let's also assume that all of the equipment is installed correctly. And
finally, let's assume that the user of the solar power system DOES NOT
KNOW how any of this equipment really works, which is why they don’t
know why it fails!
Re-cap of the Failure Scenario
• Insufficient power produced during off-peak solar conditions
• Batteries not fully charged at the end of the day
• Batteries need to be equalized on a regular basis
• Batteries eventually fail and need to be replaced
In spite of the fact that all of these problems are happening to the batteries,
the batteries are not the cause of any of these problems.
The inability of the Crystalline Silicon solar panels to produce their rated
power when there are clouds blocking the sun has already been discussed.
So this is the beginning of the chain of events that leads to battery failure."
