Oudot fysiologiset ominaisuudet ihmisissä sekä luonnossa
Re: Oudot fysiologiset ominaisuudet ihmisissä sekä luonnossa
ViestiKirjoittaja siviili2003 » 02.07.2021 10:14
kiintoisa tarina pörriäisten maailmasta:
OTHER INTERESTING EFFECTS: INSECT WING SOUNDS
A very interesting electrical effect easily observed with the WR-3 are insect wing sounds caused when insects such as bees, flies, and mosquitoes fly within a couple of feet of the WR-3 whip antenna. The resulting sound is a buzzing sound very similar to what can be heard by ear, however, this effect is caused by electrostatic discharges each time the insect's wings flap. It is thought that electrostatic charges (static electricity) are collected on the insect's wings and then and dumped during each wing beat, creating a "modulated" electrical field around the insect at the same frequency as the wings beat. Large insects, such as wasps, Yellowjackets, Bumblebees and honeybees, make particularly strong buzzing sounds in the WR-3 headphones-easily heard when those insect fly within 3-4 feet (1 meter) of the WR-3 antenna. High-pitched Mosquito wing beat sounds can be heard the small insects fly within a few inches of the WR-3 Receiver's whip antenna.
Certain kinds of flies and other insects have much more electrostatic "buzz" from them than other kinds - Bees and Horse Flies, in our observations, have the loudest "buzz" in the headphones! This may also have something to do with the composition of the insect's wing, with certain type of insect wings more prone to static electricity accumulation and subsequent discharge. There may also be insect bodily electrical discharges generated within the insect's wing muscles that contribute to this effect, and a some believe that the insect's carapace ( outer body shell) has a piezo-electric effect similar to quartz crystals, but not much is understood about this phenomenon yet and further studies are encouraged.
löytyy linkistä:
https://pe2bz.philpem.me.uk/Comm/-%20Re ... wr3gde.htm
ViestiKirjoittaja erkos » 03.07.2021 01:32
Liittyneekö tämä asia jotenkin kenties aivan viime viikkojen uutisiin
hyönteisten sähköisestä 'häirinnästä'.
Lehdistö nimittäin uutisoi, että esim Partioaitan 'hyttyskarkoituslaite'
vedettiin pois myynnistä, sillä se tappoi lähes 'kaikki lentävät hyönteiset'
hyttysistä mehiläisiin!
Ja se laite (kuten monet muut vastaavat) toimi juuri ''vastaavalla tavalla',
eli tahdistuvat hyönteisten siipien tahdistukseen, siipien nivelet katkeavat,
ja ötökät kuolevat kuolevat lennossa ja suurellakin säteellä!
ViestiKirjoittaja siviili2003 » 03.07.2021 08:47
erkos kirjoitti:Liittyneekö tämä asia jotenkin kenties aivan viime viikkojen uutisiin
mitähän päiväunia erkosin päästä tuuppaa tulemaan, vai että siivenkatkoja thermacell:
https://yle.fi/uutiset/3-11983200
ViestiKirjoittaja siviili2003 » 11.12.2021 22:20
Nyt tuli mieleen tästä kahdesta eri aiheesta että onkohan näissä ilmiöissä ja niiden selityksissä jotain samankaltaisuutta
Nimittäin MAAPARISTOSSA (Earth Battery) ja Bakteeri paristossa (Bug Battery).
Stubblefieldin maaparisto voi olla myös väitetyllä tavalla toimiva, mutta haiskahtaa myös bakteeriparistolta:
http://www.rexresearch.com/stubblefield ... field.html
https://www.nuenergy.org/the-amazing-bug-battery/
siis multaan ja maa-aineksiin kosketuksissa olevat maapariston elektrodit voivat tuottaa sähköä bakteeritoiminnan tuloksena, ainakin näissä patenteissa ennen stubblefieldiä, niin luulen
Telegraph line was not copper, neither was it insulated throughout its length. Telegraph line was bare iron wire, and was supported on porcelain insulators fixed to tarred wooden poles. Signal strength along such resistive wire would have theoretically been extremely poor, but was exceedingly strong at times. So great was the developed signal strength that operators could "remove battery cups" and work with almost no current at all. Where did this extra energy come from? From what mysterious depths did this strange power emerge? Examination of telegraph systems reveals them to be radionic tuners on a vast scale. I suggest that VRIL articulate energy, the dendritic living energy found in the ground, was at work in all these systems.
EARTH RESERVOIR
Nathan Stubblefield's experiments involved the development of earth batteries: buried metallic arrangements which produced electrical power. We find a good number of the earth battery designs in the Patent Registry. The earliest designs appeared in 1841 when Alexander Bain discovered the phenomenon. While working a telegraphic line, he chanced to discover that his leads had become immersed in water. This short-circuit through earthed water did not stop the actions which resounded through his system.
Mr. Bain took the next step to a greater distance, burying copper plates and zinc plates with a mile of ground between them. These, when connected to a telegraphic line performed remarkably well without any other battery assistance. Bain obtained a patent for his earth battery in 1841, using it to drive telegraph systems and clocks.
Stephen Vail (1837) observed the same effect, not knowing what caused it. The establishment of the first functional telegraph line seemed to require ever few batteries with time. Vail began with some 12 battery cups, reducing them gradually until 2 were needed. There came a point where he found it possible to remove even these, while operating the system.
This mystery persisted for years. I have heard such an account by a close friend and electrical engineer who reported that local telegraph stations remained in operation despite the fact that their batteries had not been recharged for a great number of years (W. Lehr).
J. W. Wilkins in England (1845) corroborated findings made by Bain, developing a similar earth battery for use in telegraphic service. An early English Patent appears in 1864 by John Haworth, the first true composite earth battery. This battery is drum shaped, having numerous solid discs mounted on an insulative axis, end braced, and buried. Their power was rated in terms of disc diameter and telegraph line distance: 1 foot diameter discs for 75 miles of line, 2 foot discs for up to 440 miles of line.
Patent Archives have revealed a great number of these devices including several remarkable operative descriptions. Earth batteries by Garratt (1868), Edard (1877), Mellon (1889), and Hicks (1890) yield therapeutic powers. Earth batteries by Bryan (1875), Cerpaux (1876), Bear (1877), Dieckmann (1885), Drawbaugh (1879), Snow (1874), Spaulding (1885), and Stubblefield (1898) produce usable power. In addition to these marvelous patents, there are those which found their way into telephonic service later: designs by Strong (1880), Brown (1881), Tomkins (1881), Lockwood (1881) provided power assistance and primary power for telephonic systems through out the countryside.
The well reputed fame of "earth batteries" centers around their very anomalous electrical behavior. The central mystery about earth batteries is that they do not corrode to the degree in which their electrical production rate theoretically demands. Exhumed earth batteries reveal little surface corrosion.
Nathan Stubblefield knew that probes (placed into various soils) reveal an amazing degree of strong electrical activity. These currents show an amazing degree of variation across any chosen plot of ground. Wet soils often reverse the expected electrical strength: weakening, instead of strengthening their appearance. Proper placements of metallic probes can produce strong currents for use.
Touching a well-grounded iron rod is a good first experiment to try in these regards. Try and find a place where power leakage into the ground is minimal, such as a park or wooded area. Take a yard-long solid iron rod whose surface is free of shellac or insulator coatings. Carefully drive the rod into the ground with a hammer. Wetted hands on the iron should produce a mild electrical sensation. These voltages may be measured. They "pin" sensitive galvanometers. The current does not cease after several weeks of activity when properly placed.
Stubblefield's observations of natural electrical manifestations led him to consider the taking of "free" electrical energy from the earth.... :mrgreen:
stubblefieldin maaparisto lienee ollut oikeasti ydinenergia paristo, koska käytti "Pitch blendeä" pikivälkettä (uraanimalmia).
vielä kermaa kakun päälle, sain kuulla maanpuolustustekniikan keskusteluissa venäläisvalmisteisen Ilmatorjuntatykin laukaisusysteemeissä käytettävästä "Maaparistosta" joka on kuin onkin < venäläinen "maaparisto" joka herätetään dynamolla tuntuu kestävän
kauemmin kuin läntiset akut,.> tämä kommentti löytyi sfnetin maanpuolustuskeskustelun narusta 17 vuotta takaperin, Antti Heikkilä käytti puheenvuoron (ei se lääkäri)
ViestiKirjoittaja tesla » 20.01.2022 05:36
Erkos! aletaan tekemään ajatuskokeita!!
ViestiKirjoittaja siviili2003 » 04.03.2022 10:47
Ompas kiintoisa patentti, josko vieläpä toimii?
tuossa on referoitu Puharichin patenttia US3629521
ViestiKirjoittaja siviili2003 » 10.03.2023 21:45
Jopas jotakin, Bakteeri patteri?
Löydetty bakteeri joka tuottaa sähköä tyhjästä!
https://www.monash.edu/discovery-instit ... -of-energy
ViestiKirjoittaja siviili2003 » 10.03.2023 22:32
Vakuutusyhtiöt ulkomailla haluaisivat nyt mielellään jonkun tekosyyn, etteivät joutuisi maksamaan henkivakuutuskorvauksia jos vakuutettu on ottanut Covid rokotteen ja sen seurauksena kuollut:
https://twitter.com/wolsned/status/1624 ... 20?lang=en
vakuutusanalyytikko Josh Stirling on havainnut että rokotetiheys korreloi suoraan ylikuolleisuuden kanssa.
analyysi perustuu brittien kuolintilastoihin
ViestiKirjoittaja siviili2003 » 11.06.2023 17:33
oudointa mitä näin tänään, punaviinimarja pensas on jo täydessä raakilevaiheessa, siitä kuva
normaalisti tämä vaihe on kuukauden myöhemmin, meilläkin pitkittynyt kevät, mutta aivankuin syksy olis tulossa, eikö kesää tulekkaan?
ViestiKirjoittaja siviili2003 » 10.02.2024 11:44
;tälle ilmiölle löytyi selitys yli sata vuotta vanhasta lehdestä : Electrical Experimenter 1920 june (kesäkuun numero, sivulta 185)
https://www.youtube.com/watch?v=lj2utMdmxBw
tyyppi on mennyt syömään pilaantunutta ruokaa
on siis tullut botuliinimyrkytys, botuliini on samaa kuin BOTOX jota jotkut ryppyiset ihmiset käyttää :D
Paluu Biologia
