Infinity SAV -magneettigeneraattori
Re: Infinity SAV -magneettigeneraattori
ViestiKirjoittaja TOP » 26.03.2019 23:58
"... recent info about Ininity.SAV team engine leaked from public forum indicates, that their dynamo is not fully passive - the bifillar coils get brief current impulse from driving electronics, before current is finally collected from them ..."
( https://e-catworld.com/2019/03/21/infinity-sav-qas/ )
Ehkäpä tämä systeemi ei olekaan ihan niin simppeli?
Inductance Energy Corporationin "Earth Engine" saattaa hyödyntää samaa ideaa: "... When the two opposing fuel sources (magnetic fields) driving the flywheel mass are in the correct position, the Engine fires a small electromagnetic charge measuring about 52-watts. This charge allows the opposing fuel sources to "see" each other, and can produce significant force to spin the large flywheel mass. This rotating mass inertia is then transferred via separate magnetic coupling to a generator which produces electrical energy ... "
( https://e-catworld.com/2019/03/15/inductance-energy-corporation-iec-shows-installed-magnet-motor-in-las-vegas-video/ )
Paluu Magneettimoottorit
Käyttäjiä lukemassa tätä aluetta: Ei rekisteröityneitä käyttäjiä ja 10 vierailijaa
