oudot videot
Re: oudot videot
ViestiKirjoittaja siviili2003 » 26.01.2012 02:27
Allan Sterling pyysi mun firman pääinsinööriä kommentoimaan tätä Jussin linkittämää videota, nää samat kommentit on sen videon Kommentointiosiossa.
http://www.youtube.com/watch?v=zF9fl4_eMiY
##Hi! A nice demonstration! Question: Have you measured the frequency it oscillates on? It should be easy by placing a wire near it which is connected to an oscilloscope or counter or any HF receiver or measuring device you might have. - continued...
.. continued: Suggestion: You should be able to lit a small flashlight incandescent bulb by placing it amid the aerial wire instead of leds. A bulb does not need diode rectifier to light up by HF current like the leds need. Your operating voltage of batteries in series appears to be about 36 volts so I would suggest start experimenting with about 24-48 V 0,5-1 W bulbs. Small bulbs are commonly used as aerial current indicators of low power HF transmitters. - continued...
... continued: Unrectified coil meters are no good for showing HF aerial currents quite as you demonstrated. Congrats for making a simple transmitter circuit for high frequency experimenters! Trying it will teach a lot more about practical and curious behavior of high frecuency (HF) currents than bare schoolbooks can! As a ham radio experimenter of practical low power HF circuits I appreciate your way of reporting about your experiments to public. Regards, OH7HJ, Finland.
JHartikka
Tip: Where to get small bulbs for high frequency (HF) current experiments? Good source for abt. 24 ... 36 V low current bulbs are those decorative Christmas lights that are connected direct to mains. These Christmas decorations have many bulbs connected in series and they start to glow from currents of tens of mA or so. Just extract as many bulbs as you need. Also the smallest car instrument panel light bulbs mey work well as HF current indicators, particularly the 24 V ones.
Battery current measuring: The batteries of this circuit are also part of a high frecuency current circuit. They make a kind of other half of the aerial. They may act as a capacitive HF lead to ground. So any common multimeter connected to batteries for current will behave funny. It may point too much or too little or even reverse. HF currents jump through their own capacitive shortcuts within the multimeter to its sensitive semiconductor measuring circuits. - continued...
... continued: Then, how to measure reliably battery current? One simple means is to again use a small bulb as a current indicator. A 6 ... 12 V 100 ... 300 mA bulb in series with the batteries should work I guess. Just check correct bulb voltage ans amperage for your circuit by trying with different bulbs. The light intensity of a glowing bulb is a very reliable indicator of true battery current of a HF circuit supply.
JHartikka
sitten tuohon Vipusen havaitsemaan ilmiöön seuraavia huomioita:
Kaveriani on kiusannut jo pitkään kyseinen hohtovalo, hänellä ne loistaa autotallin ulkovaloina, hä pyysi minua tutkimaan sitä ilmiötä ja kävinkin tonkimassa lampun pohjia, mitään selitystä en löytänyt, vaihdoin jopa vaihe ja nolla johdon keskenään ja edelleen lamput hohtaa vaikka virtakytkin katkaisee.
mittarilla mittasin sitä jännitettä mikä sai lamput hohtamaan ja se oli noin 70milli volttia, käsittämätön ilmiö, mistä avaruudesta se tulee?
Jännite katoaa kun märällä sormella koskettaa virratonta johdinta, siis olematon virtavuoto (lisäys 25.tammikuuta 2012)
Viimeksi muokannut siviili2003 päivämäärä 26.01.2012 23:34, muokattu yhteensä 1 kerran
Re: oudot videot
ViestiKirjoittaja Vipunen » 26.01.2012 15:47
siviili2003 kirjoitti:sitten tuohon Vipusen havaitsemaan ilmiöön seuraavia huomioita:
mittarilla mittasin sitä jännitettä mikä sai lamput hohtamaan ja se oli noin 70 volttia, käsittämätön ilmiö, mistä avaruudesta se tulee?
Mittasin tuon valaisimen kannan jännitteen ensin vaihtovirta asennossa 600 ja 200V mutta se ei näyttänyt mitään. Siirsin tasavirran puolelle jossa asteikot mene millivoiltteihin saakka ja siinä näyttöön ei tullut 00,5 mV enempää. Pieniä piikkejä 05 mV tuli kun koetinkynän kärkeä siirsi kierteellä tai kärjen irroiti siitä. Mittarin johtojenkin roikkuessa vapaasti, jännite vaihteli saman verran 01 - 05 mV välillä. Siirsin tilalle toisen samanlaisen lampun, kierrettäessä sitä kiinni, se välkkyi mutta ei syttynyt samalla lailla palamaan jatkuvasti. Vaihdoin juuri Kiinasta hankkimani 6V kuluttavan ja 650 lumenin (vastaa n. 55 W hehkulamppua) tehoisen led-lampun siihen kantaan, ei syttynyt ja räpsäyttänyt "aavevaloa".
Näyttää siltä että tämä on tuon lampun ominaisuus, sillä vein kyseisen lampun tuvan puolella olevaan valaisimeen ja joka saa virran eri propun (sulake) ja vaiheen kautta ja siinä se palaa myös aavevaloa.
LeMIX-niminen kupulamppu on ostettu Tokmannilta viimme syksynä ja sen hinta on n. 6,99 eeroa.
Kanta on normaali E27
Jännite 230 V
Kulutus 2W (vastaa 15 W hehkulamppua)
värilämpötila 2700 K
valokulma 180 astetta.
Maahantuoja on EcoSystems Finland
Kiinasta DealExtremeltä tilaamani led: SKU 70910
- Warm white 128-LED light bulb
- Power: 6W
- Voltage: AC 220V
- Color temperature: 3000~3500K
- Luminous flux: 640LM
- Long life and energy saving 30000 -50000 h
Hinta sisältäen rahdin: 13,41 euroa
Tilauksesta lähimpään postiin menee aikaa n. 2 viikkoa
Valoltaan ja valaisultaan paras tähän mennessä ja on kokonaan muovikuorinen. Aika näyttää kuinka hyvin tunnit tulee täyteen ;). Vastaava hieman tehokkaampi led-lamppu Suomessa, maksaa 40 eeroa. Itse tilaamalla näitä saa kerralla tilattua 3 kpl (40,23 €) sillä maksimi on 43 euroa, jonka jälkeen menee alvia ja tullimaksua.
Re: oudot videot
ViestiKirjoittaja siviili2003 » 26.01.2012 23:28
Melkein just tuommoiset lamput hohkaa, kuin tuossa Vipusen kuvassa.
Puhuin JHartikan kanssa asiasta ja syykin siihen hohtamiseen selvisi, kaverin autotallissa kulkee saman kaapelin toisessa parissa lattialämmityksen virrat jatkuvasti, ja kun sitä kaapelivetoa on noin 10 metriä jossa virraton johdin on, (se virraton johdin joka menee ledilampulle), niin tehoa siirtyy kapasitiivisesti johtimesta viereiseen johtimeen, ja kun ledit ei just tarvi muutakuin sähkönhajua niin ne pyrkii hohtamaan.
Tämä hohtoilmiö on paremmin ehkäisty näissä kalliimmissa lampuissa, joissa on käytetty kaikki ne komponentit jotka laki vaatii, mutta halpamaan tuonnissa on sellaisia lamppuja jotka ei täyttäisi suomen Tukesin määräyksiä.
Nekin hohtavat lamput sais lopettamaan hohkamisen kun lisäis sen lamppupiirin rinnalle 270.000 ohmin rinnakkaisvastuksen.
Re: oudot videot
ViestiKirjoittaja Vipunen » 27.01.2012 04:14
Näin tuo muuten on, rinnakkainen piuha jossa virta on jatkuvasti menee talon toisessa päässä olevalle lämpöpumpulle ja led-lampulle tuleva viereinen piuha käy kääntymässä ovensuussa katkaisimessa. Yhdessä kuljettavaa matkaa on noin kolmisen metriä ja kaapelissa on viisi karvaa. Netistä löysin seuraavaa tekstiä "EMC ja sähkömagnetismi".
Mitä haittaa ja mitä hyötyä? Näkyykö "mittarissa" kulutuksena?
Tuossa kiinasta tilaamassani ilmiötä ei esiinny, mutta Tokmannilta ostamasani 2W led-lampussa kylläkin. Myös samasta paikasta ostamani hieman tehottomampi ja saman hintainen Energyn 2W led-lamppu välkytteli, kun kierrin sitä kantaan. Ei kuitenkaan hohtanut.
Re: oudot videot
ViestiKirjoittaja Vipunen » 29.01.2012 19:14
Mahtoivatko ruottalaaset samppakalja sukeltajat löytää sakemannien Hanebut...? "Esineiden muoto panoo mielikuvituksen laukkaamaan ne uhuvooksi.
Re: oudot videot
ViestiKirjoittaja siviili2003 » 29.01.2012 21:25
täss on oiken mainio video:
http://www.youtube.com/watch?v=SoXm4zuGszU
jokaiselta kotikokeilijalta löytyy nää tarvikkeet, ei pitäs olla vaikeaa itse testata ja todeta outous joka on todella sitä.
kaksi metallista putkea 1.5 m pitkiä, öljypolttimen syttymuuntaja, parit konkat (mikroaaltouunin teurastus takapihalla).
pari kruunumutteria laudanpätkä, vähän johtoa ja muutama ruuvi, thats it. sitten testi testi.
Siitä nyt hätäsimmät selittämään ilmiötä, miksi hehkulamppu palaa oikosulkulenkissä.
Joko vipusella housut tutisee innostuksesta?
Re: oudot videot
ViestiKirjoittaja jussik5 » 29.01.2012 22:20
Tesla ei kyllä siitä kunniaa saa ;)
(Tesla hairpin effect)
Kunnia asiasta menee Ernst Lecherille
http://en.wikipedia.org/wiki/Lecher_lines
Ja Herzille ja Lodgelle
Jos haluaapi Tesla tekstiin aiheesta tutustua niin
http://www.archive.org/details/inventionsresear00martiala
Ja sivu 339
Re: oudot videot
ViestiKirjoittaja jussik5 » 30.01.2012 01:00
Vipunen kirjoitti:Mahtoivatko ruottalaaset samppakalja sukeltajat löytää sakemannien Haunebut
Kyseisen yrityksen sivulla on monta uutisvideoo aiheesta
http://oceanexplorer.se/
Keräävät miljoonaa kruunua retkeen ja myyvät lippuja retkelle mukaan 15000 dollariin
Re: oudot videot
ViestiKirjoittaja Vipunen » 31.01.2012 00:15
Ilta-Sanomista bongasin yleisönosastolta merenpohjassa olevalle kuva-arvoitukselle hyvinkin järkeen käyvän selityksen:
"Venäläinen amiraali Popoff suunnitteli pyöreän, lautasmaisen aluksen 1870-luvulla. Alusta oli tarkoitus käyttää rannikkojen pommittamiseen Venäjän keisarikunnan ja Osmanien valtakunnan välillä vuosina 1877–1878 käydyn sodan aikana. Aluksia rakennettiin pari kappaletta, joten kyse voisi olla samasta asiasta."
Videolla on kuvia tästä 1847 valmistuneesta pyöreästä laivasta ja siitä on myös pienoismalli olemassa:
http://www.youtube.com/watch?v=wLIKg1ycvGU
Mahtoiko olla Fiskarsin valmistamat höyrykoneet, ensimmäinen tehtiin 1836...
Re: oudot videot
ViestiKirjoittaja jussik5 » 31.01.2012 01:05
Nää tehtiin Mustallemerelle ja olivat kuulusia siitä etteivät olleet merikelposia (siis kaikki Popoffin laivat)
Joten ne olis tarttenu lennättää Suomenlahdelle ;)
Eikä ne ollu kuin 30 metriä halkaisijaltaan, toi tolla pohjassa on noin 60 m.
http://en.wikipedia.org/wiki/Russian_monitor_Novgorod
Tarkemmin, mutta venätjäks: (+kuvia)
http://keu-ocr.narod.ru/KO_04/
Pienoismalli
