oudot videot
Re: oudot videot
ViestiKirjoittaja Ville » 27.04.2018 11:49
”Howard Johnson held not just one, but three magnetic motor patents. Which he produced working models to demonstrate, before his patents were awarded to him. One of which, he fought in court for. He was finally granted this patent after Jimmy Carter, who was the president of the United States, personally contacted the patent office in Johnson’s behalf.”
Re: oudot videot
ViestiKirjoittaja Ville » 03.05.2018 09:33
Bruce A. Perreault demonstrates his capture capacitor effect discovery at his Inventor's Week end in Seattle, Washington 2003.
Yksinkertainen kondensaattori, joka varautuessaan pyörittää pientä sähkömoottoria.
Levyinä alumiini ja hiilikuitu ja eristeenä lasinpuhdistuspyyhe (mikrokuituliina).
Donald L. Smithin plasmaputkigeneraattorin (Dipole Transformer Generator) replikointia. Kondensaattorin levyinä kupari ja alumiini ja eristeenä muovikalvo. Diodeina 12 kV korkeajännitediodit, jotka on kytketty ilmeisesti siten, että sähkö virtaa, kun kupari on positiivinen ja alumiini negatiivinen. Generaattori tuottaa korkeajännite pulssitasavirtaa tai aaltoilevaa korkeajännite tasavirtaa.
Smithin mukaan magneettisten aaltojen energia (Heaviside virtakomponentti) muuttuu sähköksi, kun luodaan dipoli (North & South), johon laitetaan kondensaattorin levyt suorassa kulmassa suhteessa dipolia ympäröivään magneettivuohon.
It is found that creating a dipole and inserting capacitor plates at right angle to the current allows magnetic waves to change back to useful electrical (coulombs) energy. Magnetic waves passing through the capacitor plates do not degrade and the full impact of the available energy is accessed. One or many set of capacitor plates as desired may be used. Each set makes an exact copy of the full force and effect of the energy present in the magnetic waves. The originating source is not depleted or degraded as is common in conventional transformers.
Resonance Energy Methods
http://frienergi.alternativkanalen.com/Smith.pdf
Re: oudot videot
ViestiKirjoittaja siviili2003 » 04.05.2018 00:16
Bruce ei ole erityisemmän hyvissä väleissä Keelynetin Jerry "Pecker"in kanssa kuten Bruce mulle yksityisviestillä ilmaisi, Ja tämänkin foorumin Jussilla oli joku mielipide tai sen suuntainen Brucesta ja hänen menneisyytensä edesottamuksesta.
Brucen PPV tosiaankin on pieni termoparimateriaaleista tehty kipinäväli tyyppiä Open Air,entisten suljettujen systeemien sijaan.
Nyt Bruce on lähimpänä ns. Moray Valvea, sillä Morayllakin oli ilmalle avoin ns. Venttiili ts. ionitasasuuntaaja joka vuotaa mielellään vaan yhteensuuntaan, ehkä voisikin puhua mieluummin Wimshurst tasasuuntaajasta.
Tästä voisi siirtyä juohevasti myös Testatika laitteen yksityiskohtien tarkasteluun sillä Paul Baumann esitteli erikoisen monilevykondensaattorin (alumiini- kupariparin) magneettikentässä kuten Don Smith, nimittäin Linden Experimentin:
http://www.linux-host.org/energy/principles.htm
Tämmöinen systeemi on nähtävissä Testatika laitteen molemmin puolin (etunäkymässä plus ja miinus puolella).
piirroksessa:
Re: oudot videot
ViestiKirjoittaja erkos » 04.05.2018 15:42
Kiitos siviili hienosta sanomasta.
Tuosta Bruce asiasta sen verran, että kun hänen Uusin (muutaman päivän ikäinen) videonsa oli poistettu, niin lähetin hänelle 'kehu-/innostuneena olen' tyyppisen viestin. Bruce vastasi heti, kysyen minkälaista listietoa kaipaan?. Viime yönä lähti 'pitkähkö kysymyslista' hänen, nimenomaan vain Uusimpaan 'toimivaan 'Open Air' valvensa yksityiskohtiin.
Heti kun saan vastauksen, lataan sen sen teille kaikille nähtäväksi.
(Menin aluksi hieman halpaan hänen 'rakennusohjettaan' selaillessani. Hän puhuu useasti termopareista, mutta asiahan oli 'termopareista poikkeavasta' asiasta. Eli yhteistä ollee vain se, että valven elementit ovat eri metalleista. Kun vielä mainitsi 'valven osien keskinäisestä säädöstä' tuli mieleen: 'tavallinen kondensaattori, jossa levyt ovat eri metallista tehtyjä' ja kapasitanssi levyjen välillä mekaanisesti säädettävissä!
Minulla on muistissa, että vuosia sitten löysin useammankin 'raportin', joissa mainitaan nimenomaan eri metalleista tehdyt kondensaattorilevyt, sekä myös 'erilaisia viritelmiä kytkeä levyjä yhteen 'erilaisin yhdistelmin!? (Eräs 'näkömuistiin jäänyt' erikoisuus oli nimeltään L-kondensaattori). Kerron lisää kun kahlaan taas teratavujani.
p.s tuosta Brucesta vielä. Ensimmäinen vastauksensa minulle oli tavallaan: 'Hän on myös 'haavi' auki, miten joku kolmas osapuoli, voi poistaa Hänen videonsa, johon Hänellä itsellään pitäisi olla kaikki 'copuright' jne. oikeudet?
Heitänpä vielä pari ajatusta.
Jos ja kun tuo Bruse on 'peuhannut ajatuksiensa ja kokeiluidensa kanssa jo kymmenkunta vuotta'! niin miksi ei suurempaa 'haloota' /julkisuutta 'Radioionics otsikolla julkisesti? Esim. You Tuben kymmenen vuotta sitten ladattujen videoiden katselijamäärät ovat minimaalisia!? Onko Bruse 'huuhaa veikko vai onko hänellä oikeaa asiaa?
Siviili heittää mahdollisen yhteyden Morayn kokeisiin. Moray on monella tapaa todella paremmin esillä oleva kuin Bruce.
Re: oudot videot
ViestiKirjoittaja siviili2003 » 06.05.2018 06:26
Re: oudot videot
ViestiKirjoittaja erkos » 07.05.2018 22:14
Moikka.
Tuli Brucelta uusi vastaus.
Kertoo miksi hänen asioistaan ei edes mainita aivan kuten Siviili jo asiasta kertoikin.
Hi Erkki,
I have been discredited by the likes of Jerry Decker from Keelynet over the years. He has done the research a great disservice. Because of this people have backed off from my valuable work.
My valve which allows the production of high wattage is proprietary at this point. You should understand why.
Yes, two differing electrically conductive metals.
Fe 1 and Fe 3 are flyback transformer ferrites, nothing really unique about them. Have you studied the new diagrams?
Best Regards, Bruce more to come.'
Re: oudot videot
ViestiKirjoittaja tesla » 08.05.2018 02:37
Morot ERkkos! Mihin viittaa tuo Bruce kun puhuu noista flyback ferriiteistä?
Kuvaa siis diagrammia kaipaisin.
Re: oudot videot
ViestiKirjoittaja Ville » 08.05.2018 19:21
Re: oudot videot
ViestiKirjoittaja siviili2003 » 08.05.2018 23:22
Tässäpä Tesla juniorille kuvaa viitteeksi ja nuo Fe1 sekä Fe2 ferriitit ovat näistä kyhättyjä
Suomensin tähän alle tuon kuvan selitystekstiä:
Kokonaiskuvaus
Maapallo kylpee ionimeressä joka on aina läsnä sen ilmakehässä.
Ne pääasiassa muodostuvat kun ultraviolettivalo saapuu Auringosta imeytyen ionosfääriin joka ympäröi planeettaamme.
Siepataksemme ioneita, täytyy tuottaa vastakkaisnapainen varaus toiseen kondensaattorin napaan (C1).
Sähköstaattinen potentiaaliero (suurjännite) joka varastoidaan kondensaattori levyjen väliin, täytyy muuntaa käyttökelpoisempaan muotoon sähköä koska meidän sähkölaitteet eivät ole suunniteltu käyttämään tämän muotoista energiaa. Niitä ei voi käyttää pelkillä ioneilla.
Ne tarvitsevat elektromagneettista energiaa toimiakseen.
Yleisesti ei tiedetä, paitsi nyt, kuinka suoraan tai epäsuorasti voidaan muuntaa ionivaraus (sähköstaattinen) energia sähkömagneettiseksi energiaksi (sähköenergiaksi).
Samalla tavalla kuin vastaanotettaessa radioaaltoja, sopivasti viritetty radioioni energiavastaanotin voidaan virittää resonanssiin järjestelemällä sopivasti induktanssia ja kapasitanssia.
Komponentit vastaavat erityisiin tämän planeetan energia aaltotaajuusvärähtelyihin.
Perreaultin Plasma venttiili (PPV) patoaa varauksien tulon antenniin, varaten kondensaattoripaketin. Korkeajännite varaus joka.......
Brucen kanavan videot on kyllä ihan oikeasti outoja, sillä niihin ei just kannata tänne linkata, kun juutuubi hävittää ne melko hetimiten bittiavaruuteen, sanoisin että yuutuupi harjoittaa nettisensuuria puhtaimmillaan....
Mutta kyllähän tämmöisiä videoita kuten alla on, saa näyttää, kunhan ei mene videolla kertomaan mitään TESLA juttuja:
https://www.youtube.com/watch?v=eTOmJ7tnTQc
Viimeksi muokannut siviili2003 päivämäärä 09.05.2018 10:07, muokattu yhteensä 1 kerran
Re: oudot videot
ViestiKirjoittaja siviili2003 » 09.05.2018 09:49
Erkosille tiedoksi että näin niitä pinnoitetaan, lasia tai vaikka muita metallejakin, toisilla nanopinnoitteilla:
https://www.youtube.com/watch?v=fLehYoPzdW8
jostain joudut hankkimaan hyvälaatuisen tyhjöpumpun, mikroaaltouunin muuntajan, volframilankaa lämmityskierukaksi, iso lasikupu tai lasinen säilykepurkki.
Eipähän harmita sitten niin paljon kun se lasipurkkikin hopeoituu sisältä läpinäkymättömäksi kuten videossakin ilmenee.
Alemmassa videossa jo enempi autotalliharrastajan mallilla tehtynä:
https://www.youtube.com/watch?v=c4Sic1DRXJI
Täältä voi ostaa HALVAN tyhjiöpumpun alle 200 euroa:
https://www.ultimatemarket.com/Ultimate-Tyhjioepumppu
