ViestiKirjoittaja Ville » 17.12.2015 14:00
Mielenkiintoinen testi, jonka mukaan sopivassa järjestelmässä pienikin sisäänmenoteho (2 mW) riittää ja selitys, miksi ELF-taajuudet soveltuvat hyvin tehtävään.
Tom Bearden & Floyd Sweet. 1991. Utilizing Scalar Electromagnetics To Tap Vacuum Energy.
Antigravity Tests
Inherent in the preceding discussions is the possibility to turn EM energy into gravitational energy of either sign. In other words, one should be able to utilize Sweet's vacuum triode to produce and demonstrate antigravity.
Indeed this is the case. Sweet has also discovered the special alterations necessary to perform straightforward transformation of the internal energy in the nucleus to antigravitational energy, producing a unilateral thrust upward.
Note that the bulk of G-potential gradient (G-force-field) occurs Whittaker-wise at ELF frequencies. This explains why nonlinear phase conjugate opticians do not notice direct antigravity effects.
At the optical frequencies at which they work, the effects are so miniscule that they are negligible. This is readily explained as follows: In QM, the quantum (photon) is comprised of action (angular momentum), not just energy. It is rather like a "piece of energy welded to a piece of time, with no seam in the middle."
Since quantum change occurs in quanta, the decoupling of the energy and time components, in the continual interaction of photons with matter, exchanges energy between G-potential of vacuum and trapped mass of the atom or particle. In this exchange, small increments of time are continually being formed (and unformed, as photon emission occurs).
Consequently, each mass is moving forward in time in small incremental jumps, usually of exceedingly small magnitude. However, the energy and time trapped in a photon are canonical. The greater the piece of energy, the smaller the piece of time, and vice versa.
So if one wishes to stress the "rate of flow of time" significantly, one needs to produce large amounts of photons that have very large pieces of time, and consequently little pieces of energy.
Since the energy of the photon is directly proportional to its frequency, this means that the lower frequency photons have larger time increments, and hence endure over many "regular-sized photon absorption/emission changes" to appreciably stress the rate of time flow/production.
The bottom line is that the standard pumped phase conjugate mirror can be adapted to produce antigravity at ELF frequencies, but precisely the same adaptation at optical frequencies will have negligible effect.
With this in mind, the author requested Sweet to perform an antigravity experiment to prove the thesis. With Sweet's proprietary adaptation of his vacuum triode/PPCM, the experiment produced rather straightforward but spectacular results, as shown in Figure 5.
The experiment was performed as follows: Rigged for antigravity, the 6-lb. device was placed on a scale so that its weight could be continuously monitored. A special external load box was utilized in which multiple electric light sockets were connected in parallel.
Then the external load draw was adjusted by merely screwing in 100-watt lamps, one at a time, with measurement and observation pauses in between. The output of the device was 120 volt, negative AC sine-wave power at 60 Hz.
For each 100-watt increment, the load power was recorded and the weight was carefully recorded. The results are shown in the rather smooth, classic curve shown in Figure 5.
At 1,000 watts load draw, the previously 6-lb. device had reduced its weight due to gravity by 90 percent. At that point the signal-wave (grid) input to the open-loop vacuum triode was only 175.4 microamps at 10 volts, or just under two milliwatts.
We accent that the nominal two milliwatt input is only a gating signal. It is the organized, gated vacuum energy that is performing the action.
The experiment was stopped short of actual hovering and flying due to safety considerations. With the specific adaptation, magnetic monopoles are deposited in the magnet materials, producing internal tensile stress.
Since no explosive controlled facilities were available, and there was no wish to destroy the VT, the experiment was terminated at 90% antigravity performance.
It was completely successful, and adequately demonstrated the validity of the unified field theory concepts utilized in our approach.
ViestiKirjoittaja Ville » 17.12.2015 17:33
Palautan vielä mieleen Grebennikovin lentoalustaan liittyvän unen.
16.10.2007 Olin jossain päin Venäjää jossain vanhassa pienessä puutalossa, jossa joku nainen kertoi, että lentoalustan mekanismin voi kääntää toisinpäin. Sitten hän nosti alustan seinää vasten, napsautti kädensijasta laitteen päälle ja laite alkoi upota seinään. Nainen kertoi, että laitteella voi tehdä tunneleita ja sulattaa kalliota. Laitteesta kuului matalataajuinen suriseva tai nakuttava ääni. Hän kertoi myös periaatteesta, jolla tila voi muuttua suuremmaksi, vaikka fyysisesti tila on yhtä suuri kuin ennenkin.
Alustan tuottama ääni oli matalataajuista, mahdollisesti pulssimuotoista kimalaistaajuutta (ks. Aho -> Ring 2011), jonka äänianalyysi on osoittanut liittyvän Teslan Tele-Geo-Dynamiikkaan (ks. Puharich 1985). Laitteen seinään painuminen ja kallioiden ”sulattaminen” voisi selittyä laitteen värähtelyllä (ks. Keely - Harte 1888).
A recent application of piezoelectric ultrasound sources is piezoelectric surgery, also known as piezosurgery. Piezosurgery is a minimally invasive technique that aims to cut a target tissue with little damage to neighboring tissues. For example, Hoigne et al. reported its use in hand surgery for the cutting of bone, using frequencies in the range 25–29 kHz, causing microvibrations of 60–210 μm. It has the ability to cut mineralized tissue without cutting neurovascular tissue and other soft tissue, thereby maintaining a blood-free operating area, better visibility and greater precision.
Hoigne DJ, Stubinger S, Von Kaenel O, Shamdasani S, Hasenboehler P. (2006). "Piezoelectic osteotomy in hand surgery: first experiences with a new technique". BMC Musculoskelet Disord 7: 36. doi:10.1186/1471-2474-7-36.
Tesla discovered that the radiant energy has a spectrum of light-like energies, where the impulse duration defined the effect of each narrow spectrum. Trains of impulses each exceeding duration of 100 microseconds (< 10 kHz) produced painful radiant shocks and mechanical vibration and movement of objects.
Lindemann, Peter A. 2000. The Free Energy Secrets of Cold Electricity. United States of America: Clear Tech Inc.
Tässä kaikki tällä kertaa. Toivotan kaikille lukijoille hyvää joulua ja onnellista uutta vuotta!
ViestiKirjoittaja siviili2003 » 17.12.2015 21:30
Al Bielekin tarinaa kuunnellessa (videolinkki tuolla narussa Oudot videot), useasti hän mainitsee Von Neumannin teoreemat ja Hilbertin avaruuden, sain sellaisen vaikutelman videon tarinasta että nämä toisen ulottuvuuden tutkimukset olivat juurikin saaneet alkunsa Saksasta, josta oli muuttanut amerikan mantereelle kuuluisia tiedemiehiä.
mitäs Wikipedia kertoo von Neumannista:
https://en.wikipedia.org/wiki/Von_Neumann_algebra
ViestiKirjoittaja siviili2003 » 20.12.2015 12:10
Luin vielä kirjaa The Montauk Project
Siinä kerrotaan kuinka Philadelfia kokeessa havaitut ilmiöt saivat aikaan uuden tutkimusprojektin ja tutkimuspaikaksi valikoitui juuri entinen armeijan rannikkopuolustus yksikkö koska siellä oli jo valmiina tarvittavia teknisiä laitteita, armeija oli hylännyt paikan 1960 luvun lopussa.
tutkimukseen liittyi myös Wilhelm Reichin havainnot OR ja DOR energiasta sekä radiotaajuus 425 -450 Mhz (mikä oli suomessa entinen NMT- matkapuhelin taajuus!) ALERT!!! kännykkä säteily vaikuttaa psyykkeeseen!
Montaukissa käytettiin rannikkovartio tutkaa, siis sitä tutkapeiliä taajuuksilla 425 - 450 Mhz kohdistettuna rakennukseen jossa istui sisällä koehenkilöksi valittu mies nimeltä Duncan Cameron.
Rakennuksen ovea avattiin ja suljettiin tutkimuksen aikana kun haluttiin saada tietää mitä fysikaalisia ja psyykkisiä vaikutuksia juuri kyseisen taajuusalueen radiosäteilyllä on ihmiseen.
Tutkalähetteen tehoa säädettiin lähetteen aikana, pulssisuhteita muuteltiin, pulssin kestoaikaa ja muitakin parametreja muuteltiin, rakennuksessa jossa Duncan Cameron istui oli tietenkin sijoitettuna monia antureita ympäri hänen kehoaan ja koko rakennuksen pintoihin, kaikki nämä anturit oli kytkettynä maailman sen ajan tehokkaimpaan supertietokoneeseen nimeltä CRAY1 jonka valmistaja oli ITT, ensimmäinen transistoritietokone, kun sitävastoin ensimmäisen radioputkitietokoneen kehittäjä oli Saksasta Yhdysvaltoihin muuttanut John von NEUMANN, josta jo edellisessä viestissäni vinkkasin.
Voimme varmaan arvata mitä Duncan Cameronille kävi testien kestäessä, ei ei hän suinkaan kuollut vielä silloin, mutta hänen lääkärinsä ilmoittivat että aivokuvaus antaa tuloksena saman kuin henkilö olisi aivokuollut,ja lisäksi hänen luustossaan oli tapahtunut vakavia muutoksia,tässä oli kuitenkin ihmeellistä että Duncan pystyi vielä kävelemään kaikesta huolimatta, myöhemmin hän kuitenkin tuli terveemmäksi kun ei enää osallistunut kokeisiin.
Useat muut koehenkilöt menettivät henkensä noissa testeissä.
Nyt alkaa varsin mielenkiintoinen selostus kokeista:
Kokeisiin kutsuttiin mukaan henkilö nimeltä Al Bielek, jälleen koehenkilönä sillä hän oli myös selvänäköinen henkilö, tutkimuksia jatkettiin pienemmillä tehoilla jotta koehenkilöt jäisivät eloon, huomattiin nimittäin että kyseinen radiotaajuus (425 -450 MhZ) on vuorovaikutus suhteessa ihmisen psyykkeeseen, pulssisuhteita muuttelemalla saatiin koehenkilön psyykkistä vireystilaa muuteltua korkean euforian – onnellisuuden kokemuksen ja syvän depression- masennuksen välillä.
Kyseisen tutkan taajuuksia testattiin myös läheisten asutuskeskusten ihmisiin (tietenkin heidän tietämättään) ja vaikutuksena oli mm. rikollisuuden räjähdysmäinen kasvu säteilytyksen aikana.
Yhtenä rinnakkaisena tutkimushaarana saatiin selville kuinka ihmisen ajatuksia voidaan lukea hänen energia aurastaan, Duncan Cameronin testihenkilön antureista, se suuntasi tutkimuksia ajatustenlukulaitteen kehittämiseen, ja Montaukissa onnistuttiinkin vuosien tutkimuksien tuloksena viimein niin hyvin että koehenkilö kykeni ohjaamaan tietokoneen näyttöruutua pelkästään ajattelemalla kuvia 2 ulotteisesti ja jopa viimein kolmiulotteisesti.
Eräs todella kiintoisa havainto liittyi tutka-antenniin ja sen ominaisuuksiin joista ei tiedetty aiemmin mitään, nimittäin kun antenni käännettiin 180 astetta ympäri jolloin tutkakeila osoitti kohti taivasta mutta tutkakeilan takapuoli osoitti kohden koehenkilöä, havaittiin toinen ennen täysin tuntematon voimavaikutus kohdehenkilössä, kohdehenkilön psyykkiset voimavarat kasvoivat moninkertaisiksi, tavallisesta koehenkilöstä tuli selvänäköinen ja hänen kykynsä käyttää ajatusvoimia esineiden siirtelyyn käsin koskematta.
Tästä lähti liikkeelle monta uutta tutkimuslinjaa, kuten vaikkapa kuinka matkustetaan ajassa eteen ja taaksepäin, juuri siihen mitä tapahtui Philadelfia experimentissä.
Montaukissa kokeiltiin myös koehenkilön avulla tutkan modulaatiotaajuuden kautta syöttää lähiasutuskeskuksien ihmisille ajatuksia, eli siis vaikuttaa psyykkisesti halutulla tavalla, siinäkin onnistuttiin erinomaisesti, tästä alkoi maailmanlaajuiset kokeet Mielen kontrollointiin, niitä kokeita on tehty monissa sotakonflikteissa, kuten vaikkapa Irakissa, jossa kyseisellä menetelmällä saatiin vastustajan sotilaat toimintakyvyttömiksi.
Aikamatkailun avain oli ihmisen ajatusenergia ja sen avulla voitiin muokata koeympäristön magneettikenttää tutkan lähettämällä 450 Mhz taajuudella, jolla taas oli vaikutusta ajan vääristymään, aikaa oli siis mahdollista venyttää ja taivuttaa.
Selvänäköisen kohdehenkilön aivoihin muodostuvat kuvat on mahdollista monitoroida tietokoneen näyttöön, kohdehenkilö on mahdollista hypnotisoida ja saattaa hänet palaamaan historiassa taaksepäin vaikkapa useita tuhansia vuosia, ohjata hänen huomionsa mihin tahansa maapallolla ja saada reaalinen kuvatallenne siitä mitä hän näkee ja kokee tuossa regressiossa.
Ja niitä kuvatallenteita on tallennettu jo mahtavia määriä Montauk projektien seuraajien aikana, myös nykyisin.
(tämä menee jo yli minunkin hilseen, siviili2003 huom.)
Al Bielek kertoo näistä psyykkisistä matkoistaan niin tulevaisuuteen kuin menneisyyteenkin joillakin youtube haastatteluillaan.
Tärkeinhavainto siis: 425 – 450 Mhz taajuudet aiheuttavat joko hyötyä tai vahinkoa ihmisen psyykkeelle, riippuen siitä kuinka kyseisiä taajuuksia moduloidaan ja pulssisuhteutetaan, niillä taajuuksilla on mahdollista syöttää valittujen ihmisten aivoihin käskyjä ja komentoja joiden avulla kyseinen kohdehenkilö saadaan toimimaan toivotulla tavalla, kohdehenkilö kokee pakkomielteitä ja luulee että hänelle puhuu itse Jumala.
Montauk projektin rahoittaja oli yksityinen taho, siksi Yhdysvaltain kongressin asiakirjoista ei löydy mitään rahamenoa valtion budjetin määrärahoista kyseisen projektin toiminta-ajalta vuodesta 1970 -1981 väliseltä ajalta.
Kuka tai ketkä sitten lienevät tämän mielenhallinnan rahoittajat, ei ne mitään köyhiä voine olla?
Pitäisikö meidän tiedustella siitä rahoituksesta maailman Raha-eliitiltä, tietäisköhän George Soros asiasta jotain, tai Jacob Rotchild?
ViestiKirjoittaja jussik5 » 20.12.2015 23:42
Duncan Cameron oli Al Bielekin veli, silloin kun Al Bielek oli vielä Ed Cameron.
Kuuntelin haastattelun ja löysin monta kohtaa jotka eivät tuntuneet uskottavllta,
saatika että nykyinen Al Bielek olisi täysissä ruumiin ja sielun voimissa.
Kokonaisuudessaan hyvin sekava tarina.
ViestiKirjoittaja siviili2003 » 21.12.2015 21:22
Tämä kirja Montauk Project - Experiments in Time- Preston B. Nichols with Peter Moon, on kyllä paljon teknisissä yksityiskohdissa syvemmällä kuin Al Bielekin haastatteluissa ikinä.
Olen lukemassa sitä kirjaa sivulla 86 ja nyt jo täytyy todeta että näillä ohjeilla jo rakentaisi replikan Aikakoneesta, noh jännitys tiivistyy loppua kohden- kaikenkaikkiaan kirjassa on sivuja 156.
Sivulla 86 kuvaillaan Nikola Teslan 1920 rakentamaa laitetta joka lukittui maapallon pyörimiseen, mutta mitä sillä saadaan aikaan - jatkanpa lukemista.
Muodostuu aukkoja muihin ulottuvuuksiin..... Valkoista kohinaa... Teslan pulssitettuja DC pulsseja... hänen litteisiin käämeihinsä 3Dimensionaalisesti....Zero time....Space time.
Ai kun on jännää, suosittelen kaikkia kielitaitoisia kiinnostuneita hankkimaan kirjan, ei täällä voi kaikkea foorumissa paljastaa.
Juuri tämä allamainittu kirja:
http://www.amazon.com/The-Montauk-Proje ... 0963188909
voipi löytyä myös sähköisenä jostain, Jussi varmaan löytääkin.
ViestiKirjoittaja siviili2003 » 22.12.2015 01:07
kiintoisia videolinkkejä:
https://www.youtube.com/watch?v=ks7GSmUnV3A
https://www.youtube.com/watch?v=WE4e-Fp1UZE
pääsette hyvin tunnelmaan mitä tulee Montauk Projectiin sillä näillä kahdella jutulla on YHTEYS toisiinsa.
tässäpä näitä joulun ajan lukemistoja:
http://www.bibliotecapleyades.net/monta ... ontauk.htm
http://www.stealthskater.com/Documents/Montauk_04.pdf
ViestiKirjoittaja siviili2003 » 22.12.2015 21:30
Montauk Projekt kirjasta joitakin yksityiskohtia:
Siinä puhutaan kokonaisjärjestelmän synkronisoinnista esimerkiksi maapallon omaan biorytmijaksoon jonka pituus on 20 vuotta, eli vuodet 1943, 1983, 2003, 2013 jne ovat hyviä vuosia aloittaa kokeet, sillä tuolloin spacetime vortex on hyvin vakaa, monta kuukautta putkeen, vähiten siis häiriöitä, olivat käyneet myös maapallon tulevaisuudessa vuonna 6037 jossa oli ollut täysin autio kaupunki jonka keskustassa seisoi kultainen hevonen jalustalla, se aika oli jotenkin oudosti tutkijoita kiehtonut.
Olivat käyneet tutustumassa Marsissa Richard Hoaglandin havaitsemiin pyramidiin ja Marsin kasvoihin, ja peruuttaneet historiassa taaksepäin peräti 125 000 vuotta löytääkseen viimeisiä elonmerkkejä.
Näissä interferenssi aalloista 30 Hz on jotenkin merkityksellinen, ja elohopea aitohopea lejerinki ja siitä tehdyt värähtelypiirit, (sehän on hammasamalgaamia) sillä elohopealla on joku outo kytkös eetteriin.
Amplitudimoduloitua valkoista kohinaa sekoitettuna tuohon 425 MhZ taajuuteen tuotti vortexia, spiraaliantenniin, johon muodostui ikkuna, jonka kautta saattoi katsella menneisyyteen ja tulevaisuuteen, viimeisimpinä vuosina tuolloin 1982 eteenpäin saivat kehitettyä systeemit niin pitkälle ettei Duncan Cameronia tarvittu enää ohjaamaan prosessia vaan saatiin ohjelmoitua tietokoneeseen vaadittavat parametrit joilla voitiin space time vortexia ohjata haluttuun paikkaan ja aikaan.
Uskoisin että joku jatkaa kokeita vielä 2023 vuonnakin, mihinkäs se tietotaito olisi näinä menneinä vuosina kadonnut, jotkut salaseurat matkailee ajassa varmaan parasta aikaa.
Viimeksi muokannut siviili2003 päivämäärä 23.12.2015 14:54, muokattu yhteensä 1 kerran
ViestiKirjoittaja siviili2003 » 23.12.2015 04:35
Huomio huomio
Samainen Montauk projekti kirja löytyy tästä mainitusta linkistä, sivujako on eri eli sähköinen pdf versio sisältää puolet vähemmän sivuja kuin alkuperäinen paperinen kirja, siksi minun sivunumero viittaukset pätee vaan paperiseen kirjaan, ei tähän Montauk_04.pdf
Niin joo ja kuvat näkyy sähköisestä versiosta puuttuvan.
Luultavasti Ville on ehtinyt lukea kirjasen ja antaa meille oman raporttinsa?
ViestiKirjoittaja siviili2003 » 23.12.2015 15:04
Tuossa linkissä:
sivulla 54 - 55 kuvataan jotain radiovastaanotinta jonka värähtelypiirit oli tehty aitohopea - elohopea lejerigistä, kirjoittaja kertoo siihen käytetyn peräti 75 paunaa Hopeaa, RCA nimisessä firmassa oli kyseinen laite, tai muutama koko maailmassa niitä edes tehty, silloinkun niitä oli valmistettu niin Nikola Tesla oli niitä suunnittelemassa, jonkun käyttäjäkokemuksia kuvataan että kyseinen radiovastaanotin tuotti/vastaanotti jotenkin outoja interferenssejä.
Nämä vastaanottimet oli tehty vaan ja ainoastaan sitä yhtä tarkoitusta varten, eikä siksi alettu niitä sarjavalmistamaan alun alkaenkaan, Vastaanottimen tyyppi oli FRR24.
Tässä videolinkissä väitetään olevan juuri sen:
https://www.youtube.com/watch?v=yIiC45MhYyY
