Tehdään oma kuulokoje elie Neurophone
ViestiKirjoittaja tesla » 12.03.2019 11:56
Sitten kuulee kaiket äänet. Vituttaa kun ei voi kuulla kaikkea mitä tarviisikaan. Tahtoo olla lepakko!
Naksuttelee sitten vain pimeässä ja ravaa metikössä risukon läpi kuin hirvi konsanaan kiima-aikana.
http://www.neoneurophone.com/
Tossahan on jäbä vääntänyt jos jotain mikä tekee mielenkiintoista. Mut siis. Toihan on vain ultraääni-transduseri.
Ei pitäis olla kakaraversion rakentaminen vaikeeta. Aivan supahyödyllinen vekotin!!
Any hands up??!
On July 24, 1962 in Bellaire, Texas in Flanagan's shop in the attic of his parents home,
I personally witnessed proof-of-principle demonstration of a direct linkage between a crystalline electronic
circuit and the colloidal system of the human nervous system.
The device called the "neurophone" by Flanagan, was a very simple gadget. It used those ancient
devices known as vacuum tubes. It used a 6L6G tube running as a 35 Kilohertz oscillator; the output
of the oscillator was amplitude-modulated by the output of ant single channel hi-fi system through
suitable impedance matching transformers, etc. This amplitude modulated 35 kilohertz signal then
went through a cheapie stepup transformer so that the output was very high voltage (about 4 kilovolts,
as I remember) but at very high impedance. Flanagan fed this signal through a length of ordinary TV antenna
twin lead to a pair of rubber pads about six inches in diameter that he had filched from a "relaxicisor"
muscle relaxing device. Each pad consisted of a 1/16 inch thick rubber sheet, a piece of copper window
screen to which was soldered one of the wires of the twin lead, and the rubber covering of the relaxicisor pad.
The rubber insulation kept one from getting zapped, although the shock wasnt painful....just annoying.
Put a signal into the neurophone input, peak the frequency, peak the modulation to 100%, and then hold
the two pads to your body....anywhere.
And you heard music playing in your head!
Although the pads worked better and you got a louder signal with the pads on your bare skin, it would work
through a layer of clothing.
And it worked regardless of where you put the two pads! You could put one on your shoulder and the
other on the sole of your foot...and you would still hear whatever program material was being
played into the neurophone form the hi-fi system.
http://www.rexresearch.com/flanagan/neuroph.htm
